02-08-2023 08:34 AM - last edited on 02-08-2023 08:37 AM by CodeShepherd
Are there any new Informations how to access the remanent memory from outside the PLC (read and write) - maybe from Node-RED?
02-08-2023 08:44 AM - edited 04-24-2023 09:32 AM
In C++ it is enough do define the variable as persistent and then use standard create node function. If there is already a datum available (e.g. after reboot), you will get back the value of it.
For Node-RED writing own persistent data the easiest way to use the active configuration(app data) as a file based storage. See this topic.
Reading the persistent data created in the PLC works like reading any other variable.
You could also use "helper apps" like the KVD (KeyValueDatabase) app coming up with next release or a self created app to give you an interface for creating own data layer nodes and so persistent data.
