Hello
The controller on customer's plant always report an error message: " Failed to start Automatically fetch and run repair assertions". Looks like a system error not from app.
The error happens after upgrade ctrlX image and all apps to newest version of V0112.
What does it means? What the reason? Do I need to process it? If there are potential risks?
App version (details in picture):
Automation Core: 1.12.8
Device Admin: 1.12.6
could you please send me a private message with your contact data and the serial number of your ctrlX CORE? Also a system report would be helpful.
Ok, I send you an email.
Sorry for the late reply.
This message is generated by the snapd app:
Snap-repair is cyclically triggered by a timer and generates this Log messages https://github.com/snapcore/snapd/blob/master/data/systemd/snapd.snap-repair.timer#L8
But this does not refer to a concrete error and can be ignored. If you worry about this, please deactivate the output of trace messages.
Thanks for your support. The error message was traced when updagrade the system image. So the customer was warried when things was different with version before.
The error message is not printed now.
