Get Device SN
MauroRiboniMX
Get Device SN
Hi to everyone,
I am supporting a potential ctrlX world partner who wants to create an app that uses the ctrlX core SN as a varibale inside his app.
Is there a way from inside an (SN)APP to get this value? I know that is possible to achieve it using rest API but this implies that the app knows the customer credentials which are not standard.
Really thanks 🙂
5 REPLIES 5
Jochen_Mueller
Re: Get Device SN
Hello Mauro
with the RM22.03 partner apps can have the possibility to use a "Service_To_Service" authentication.
https://boschrexroth.github.io/ctrlx-automation-sdk/s2sauth.html
Means the app itself can have the access to read the SN via REST. No need to insert user credentials.
Jochen
MauroRiboniMX
Re: Get Device SN
I was defenitely looking for something like that. Thanks 😎
Mauro
Re: Get Device SN
Hello Jochen_Mueller,
that's exactly what I was looking for. Sounds like a good solution.
Can the described "Service_To_Service" communication also be used with an unsigned app during app development to build in and test the function?
In this case the app is not signed.
WolfgangDannert
Re: Get Device SN
Does anyone know anything about this and can answer the question?
Re: Get Device SN
The app does not need to be signed for this.
