Get Device SN
Get Device SN
MauroRiboniMX
Contributor
Hi to everyone,
I am supporting a potential ctrlX world partner who wants to create an app that uses the ctrlX core SN as a varibale inside his app.
Is there a way from inside an (SN)APP to get this value? I know that is possible to achieve it using rest API but this implies that the app knows the customer credentials which are not standard.
Really thanks 🙂
5 REPLIES 5
Jochen_Mueller
Hello Mauro
with the RM22.03 partner apps can have the possibility to use a "Service_To_Service" authentication.
https://boschrexroth.github.io/ctrlx-automation-sdk/s2sauth.html
Means the app itself can have the access to read the SN via REST. No need to insert user credentials.
Jochen
I was defenitely looking for something like that. Thanks 😎
Mauro
Hello Jochen_Mueller,
that's exactly what I was looking for. Sounds like a good solution.
Can the described "Service_To_Service" communication also be used with an unsigned app during app development to build in and test the function?
In this case the app is not signed.
WolfgangDannert
Does anyone know anything about this and can answer the question?
The app does not need to be signed for this.
