Cannot add module on node-red
KevinD
I know this topic has been discussed several times on the forum.
I tried to apply everything I could find and I can't add a library via manage palette on node-red.
I always have the following message:
2022-11-28T21:33:02.331Z Install : node-red-node-mysql 1.0.3
2022-11-28T21:32:59.339npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-node-mysql@1.0.3
2022-11-28T21:33:02.229Z [err] (node:3169) Warning: Setting the NODE_TLS_REJECT_UNAUTHORIZED environment variable to '0' makes TLS connections and HTTPS requests insecure by disabling certificate verification.
2022-11-28T21:33:02.229Z [err] (Use `node --trace-warnings ...` to show where the warning was created)
2022-11-28T21:33:04.616Z [err] npm
2022-11-28T21:33:04.617Z [err]
2022-11-28T21:33:04.618Z [err] ERR! code EHOSTUNREACH
2022-11-28T21:33:04.619Z [err] npm
2022-11-28T21:33:04.619Z [err]  ERR!
2022-11-28T21:33:04.619Z [err]  errno
2022-11-28T21:33:04.619Z [err]  EHOSTUNREACH
2022-11-28T21:33:04.676Z [err] npm
2022-11-28T21:33:04.676Z [err] ERR! request to https://registry.npmjs.org/node-red-node-mysql failed, reason: connect EHOSTUNREACH 104.16.17.35:443
2022-11-28T21:33:04.689Z [err]
2022-11-28T21:33:04.689Z [err] npm ERR! A complete log of this run can be found in:
2022-11-28T21:33:04.690Z [err]      /root/snap/ctrlx-node-red/470/.npm/_logs/2022-11-28T21_33_04_679Z-debug.log
2022-11-28T21:33:04.716Z rc=1
I configured the DHCP in the connections and I adjusted the date and time parameters.
Can you help me?
Thanks,
Kevin
As you said solution was discussed several times before: You need to connect your ctrlX CORE to the internet.
Your settings look a little bit strange to me as you are using 192.168.1.1 as a gateway but your internet router seems to be connected in the 10.141.29.x subnet. If you are connected to a router with DHCP functionality that provides free internet leave the DNS and gateway open as you will get the correct one automatically. See this post.
If you are connected behind a corporate proxy (in a company network) and the router will not grant you free internet you will have to use a proxy to get it via your PC. See this blog post for further information.
See this post for a ctrlX COREvirtual.
I had done things wrong
I was connected to the router in wifi for internet on my pc and I used the same router with an ethernet cable connected to my pc and another connected to ctrlX to access the ctrlX.
I have disabled wifi on my pc and enabled windows dhcp.
I also removed the default gateway and the DNS for the ctrlX as you suggested.
I can install modules on node-red now.
Thanks,
