Can apps be installed on micro-SD card?
redford
Because of the internal memory size of ctrlX CORE, is it possible to install "big size apps" on micro-SD card? Is there any limitation of that?
Thanks!
7 REPLIES 7
Jochen_Mueller
not yet.
But in the future it is planned to use external data storage (e.g. SD-card) to store backups or to extent the internal storage.
finishing date open
aFouraker
When will this be available?
Currently it is planned to realize this feature for RM 21.11.
Hi @Jochen_Mueller
For the latest update 22.07, can we already install apps on a micro-SD card?
This feature got delayed because of prioritization and is actually planned for version 1.18 (RM22.11) coming up end of November.
Can we install apps on standard sd-card with the latest update 22.11?
That's the situation with the version 1.18:
Data extension notes V1.18 / RM22.11
  • USB devices should be used too.
  • No Apps can be installed at the extented storage. (only at the internal memory!)
  • for every installed app a secured area will be created at the data extension (only the own app has access to this area)
  • will be formated (EXT4) and encrypted (needs a reboot) in the service state (safe state) - depending on the size it takes time
  • SD-card (and USB-device): max size is (32GB???).
  • can only be used at this device. Any plug out and plug in will start a new formatting and new data encryption with new formating (deleting existing data)and encrytion
Jochen
