9 hours ago
Hi community,
as part of a mere extra curricular activity, I implemented an assistant for coding in NodeRed via a chatbot dashboard.
The main features of this flow are to:
Please find more information along with some use cases/screencasts in the ppt attached. The source code as .json file can directly be imported in NodeRed and is attached as well in the .zip file.
Since it uses the cURL command for the API, I would expect a straightforward implementation of OpenAIs models, but this is not done. I was hoping for an API to AskBosch, but could not convince Bosch BD that this is not just another chatbot.
Looking forward to your feedback,
Markus
