cannot publish to core
I want to publish my project to a real ctrl x core.  I have a valid license on the ctrl x core.
However, I am not able to publish succesfully.
I have tried both via VPN and a local connection. Firewall is turned off.
The ctrl x is not automaticially found and when entering the ip and port manually and try to login (default username and password, admin and boschrexroth) I see the following message:
I
I have tried reinstalling the app multiple times, as per this suggestion Solved: Connect To Remote WebIQ Server Environnment Connec... (boschrexroth.com)
Is there anything I am doing wrong?
Best reply by webiq-sk
What happens when you enter http://192.168.2.10:10123/ in a browser on the same system WebIQ Designer is running? If it also does not show the WebIQ Runtime Manager then this should be fixed first as it means there's no WebIQ running on 192.168.2.10 or it's not running on port 10123 if you have changed the port manually (which is discouraged) or there is a firewall blocking the access.
When using WebIQ 2.14 on ctrlX the automatic discovery has been disabled because of a lackup issue after some time.
View original
