Hi all,
i am not able to start the web iq server at my own laptop, were the virtual core is running to test my created HMI developed by web iq developer. I had read in the quickstart WEBIQ...PDF, that the virtual Core has an issue with port forwarding. Now the virtual core is running but the WebIQ Server stops anytime. If i start the hmi the server is not reachable.
Is there any possiblity to run with an virtual core?
Hello
did you stop this service?
Important note for ctrlX CORE virtual: In case of Network Mode "Port Forwarding", 10123:10123 must be added to the list of forwarded ports (10123 is the WebIQ Connect default port) and the Service has to be stopped otherwise the ctrlX COREvirtual does not start.
