Execute JS Local Script inside certain container
Hemingway
I've implemented local script which generate table of widgets according to their index.
for (let i = config.count - 1; i >= 0; i--) {
                // Clone group config for composite
                const myConf = shmi.cloneObject(groupConfig);
                // Change the name of the composite, so that they are not all named the same
                myConf.name = 'row-' + i;
                // Set placeholder values of the composite
                myConf.replacers = {
                    itemIndex: i
                // Create the composite dynamically
                groups.push(shmi.createControl("group", holder.element, myConf, "div", "after"));
Now this code insert table dynamicaly after my holder element: list-target container. How to change code to insert table directly to the list-target container?
5 REPLIES 5
webiq-sk
Quick answer: choose the correct widget for "holder". If you post the full code maybe help is easier as exactly the interesting part - how "holder" is defined - has been omitted form the example.
For that using shmi.onReady() is a must, please see the scripting demo for an example on this.
Hemingway
This is my full code, where `list-target` is a container with specified dimensions:
(function () {
    const MODULE_NAME = "jsonList",
        ENABLE_LOGGING = false,
        RECORD_LOG = false,
        logger = shmi.requires("visuals.tools.logging").createLogger(MODULE_NAME, ENABLE_LOGGING, RECORD_LOG),
        fLog = logger.fLog,
        log = logger.log,
        module = shmi.pkg( MODULE_NAME );
    // MODULE CODE - START
    /* private variables */
    /* private functions */
     * get the group template id dynamically by the name and category of
     * the composite, so you don 't have to enter the grouptemplateid hardcoded
     * @param {string} name composite name
     * @param {string} category composite category
     * @returns {string} found grouptemplateID
    function getGroupTemplateByName(name, category) {
        // Get a reference to the existing group configs
        const groupConfig = shmi.requires("shmi.visuals.session.groupConfig"),
            iter = shmi.requires("visuals.tools.iterate.iterateObject");
        let found = null;
        iter(groupConfig, function (group, groupName) {
            if (group.label === name && group.category === category) {
                found = groupName;
        return found;
        let groups = [];
        const cancelable = shmi.onReady({
            controls: {
                holder: ".list-target"
        }, function (resolved) {
            // Retrieve reference to widgets and config object from "config.js"
            const config = shmi.requires("config").config.list, // gets the config from config.js
                holder = resolved.controls.holder,
                groupTemplateId = getGroupTemplateByName(config.compositeName, config.compositeCategory),
                template = "res://" + groupTemplateId + "/template",
                groupConfig = {
                    "template": template,
                    "groupId": groupTemplateId,
            // Creates as many composites as are in "count"
            for (let i = 0; i < config.count; i++) {
                    itemIndex: i
                groups.push(shmi.createControl("group", holder.element, myConf, "div"));
            cancelable.cancel()
            groups.forEach(function (el) {
                shmi.deleteControl(el, true);
            groups = [];
    // MODULE CODE - END
    fLog("module loaded");
webiq-sk
Please note that holder.element returns the HTML DOMNode, however if you inspect the container HTML element using F12 in your browser you'll find out that there is an additional element - the margin-compensator.
Instead of using the createControl method you should use the widget's own addControl method. This will add it where it belongs.
Hemingway
Now, I am creating new LS box.js and I am trying to insert all content into 'box' container, but system displays nothing. Could you please check my box.js?
webiq-sk
A few notes beforehand:
  • you removed the onDisable function - this might break functionality, can cause memory leaks which can crash the browser after hours, days, weeks, months or years - please add it back
  • please add the canceable.cancel() call to the onDisable function, otherwise this will cause memory leaks if you remove the widget(s) the script is waiting for but don't remove the LocalScript
  • whenever you use addControl you have to use deleteControl in the onDisable function to prevent memory leaks
  • It doesn't help putting the LocalScript into a container as it will be added to the HEAD of the HTML page anyway. Location of LocalScript is only relevant inside Panel widgets, i.e. a LocalScript is only rendered when included, e.g. in a screen view only if that screen view is shown. It doesn't hurt though.
  • do not use shmi.ctrl in a LocalScript, because you cannot be sure that the widget has actually been initialized when your LocalScript is executed - you have to add ".box" to the shmi.onReady call
Regarding the issue: when you inspect the generated HTML code you will see that the composite widgets are in there, they are just empty:
I would start from there and see if it works after setting the script up correctly.
