Creation of a package with ui-actions and local-scripts
With the help of the docu I created a package with some ui-actions.
  • I created the package structure and copied the ui-action js files into js/custom-libs/local-scripts
  • I can install the package successfully
  • The ui-actions are selectable in the ui actions of the button, but the parameters are not displayed correct.
  • I found the parameter definition under <workspace>\json\scripts\ui-actions.json and copied it into the package
  • But not I get the error in package manager:
  • What is the correct way to implement the package correct?
Best reply by webiq-eg
Yes, you are right, sorry. Attached is a new package which should work now.
Many greetings
webiq eg
ui_example.zip
1.29KB
View original
