03-15-2023 12:08 PM
we whant to start a basic movement with ower own application.
At the momen we are using "IndraWorks DS 12V10.0177" for this purpose. Setting speed, start and stop position and hitting "Start".
What do we need to "just" hit the start command with our own software.
we have:
HCS01.1E... with FW: FWA-INDRV*-MPB-17V16-D5-1-NNN-NN
thanks.
03-15-2023 01:44 PM
We have a API for the drives called EAL, is avaiable as a free download on our homepage:
https://www.boschrexroth.com/sv/se/media-details/e8408909-301d-41e2-a0d6-eb1f64282dce
Works with C/C# etc, you didnt specify a language.
Then if you have a ctrlX CORE you can also use the REST API to run a drive with the CORE as a gateway.
Depends on you'r setup.
03-16-2023 09:58 AM
c# would be ok. But for our purpose any language would be ok, as long it is free of charge 🙂
