upload customized json schema for configuration
cchang
Hi everyone,
I would like to enable user to get auto complete while editing the json configuration file.
How can I do that? It looks like intelliJ is already running with some json schema.
Is there any way to upload json schema file that IntelliJ can use the schema for auto complete?
If it is possible to to set $schema using the addresses under "types" in datalayer?
I tried to add "$schema": "setting.schema.json" doens't work, since it is interpreted as inmemory://model/settings.schema.json
nickH
Hi @cchang
I just tested it with our ctrlX Key Value Database app (which also has json files and schemas in the active configuration). And its possible to use auto-completion. See my screenshot: press CTRL-SPACE while editingpress CTRL-SPACE while editing
The schema in this case is located in the folder "schema". I tested it with Version 2.6.
nickH
Another hint: In your screenshot it looks like your schema has got the size of 0 Bytes. Maybe there is the problem.
cchang
Hi nickH,
thanks for your reply.  I found the problem.
After adding the content to schema, and the file must be closed and reopened. Then it works!
