07-01-2021 03:48 PM
→I downloaded the latest sdk SDK V1.8.0 - RM21.03
→I executed the hello.webserver by amd64 , there is the error happened(I did not change anything).
can anyone tell me why and how to resovle it
07-01-2021 04:15 PM
Did you open the SDK from the Windows location in VSC? Please copy the SDK via "cp -r" to your environment to prevent access errors.
07-02-2021 02:53 AM - edited 07-02-2021 03:29 AM
thank you for your reply.
I tried again.
It is ok.
reason:
→I copied the sdk to the environment
→ I did so more operations before executing amd64 that I could not access sdk correctly.
