08-24-2023 09:21 AM
hello, I have to save a txt file to the path
/var/snap/rexroth-solutions/common/solutions/activeConfiguration/
in my web UI, there is no configuration Item, so how can I create a file in the path?
08-24-2023 02:53 PM
Which version are you using?
08-24-2023 05:24 PM
my version is 1.20, Is it possible that I need access to write?
08-25-2023 08:28 AM
In Ver.1.20, how can I get the right path of the page as below:
maby I write a wrong path of page, so I can't write a file in it. Howerver, I can upload a txt file in it.
08-25-2023 10:58 AM
Some of the files are simply write protected by the provider of this data.
Did you try using WebDAV?
You can also down and upload the complete configuration and insert your file.
Also via the IDE app files can be managed.
For access via own snaps see this topic.
