My intention is to streaam real-time data to my web UI integrated with the CtrlX Core dashboard. I have an UDP server implemented in Node.js to collect data from external sensor, and web-server cloned from the go.hello sample.
I have a Node.js WebSocket server implemented in the same snap application with the UDP server. It's working on my own computer w/o snap. The problem is that I'm unable to allow access to the WebSocket server, even if I know how to enable access to the UDP server. From the log file I can see that the WebSocket server is running, but not accessible. Propably something wrong with my config files.
I wonder if there's any example available how to implement WebSocket server, so that I could compare my configurations.
