02-08-2023 11:37 AM - edited 02-08-2023 11:59 AM
Hi all,
I am working with the SDK 1.18 and I am trying to test the webserver example from the python examples in the SDK, but unfortunately I receive some warnings when creating the snap and when I try to test the app in the ctrlX CORE it does not work and stays in "The app is currently not available"
I have not done any change in the webserver sample and I have just run the build-snap-arm64.sh file and it is able to create the snap but I receive these warnings:
I have noticed that it is not able to download that files as you can see here:
However, if I test the connection it works fine:
If I add the libraries in the .yaml file as shown here:
I receive the messages:
I attach the terminal output when generating the arm64 snap file and a .zip file with the webserver folder so you can also test it.
Thank you very much in advance.
Nicolas
02-08-2023 04:36 PM
The AMD variant of the snap is running on my side but the ARM not. We are investigating this issue.
11-13-2023 01:49 PM
Did you try using the version 1.20 of the SDK? Examples were reworked there.
11-27-2023 04:25 PM
I have the same problem as sanX, how can I install the sdk version 1.20 on the App Build Enviroment ?
11-27-2023 05:04 PM
3 weeks ago - last edited 3 weeks ago
Hello @CodeShepherd,
I tried with the version 1.20 of the sdk following this post and i get the same error as before when i build an arm64 snap :
@sanX Did you manage to build it without this problem ?
Thank you in advance,
Félix
2 weeks ago
Hi @Felix_
Have you tried to install the snap on a ctrlX CORE X3?
I think snapcraft might be printing out warnings which are not really relevant.
2 weeks ago
Hi @nickH
Yes, I've realized that these warnings don't affect the build.
Thank you for your reply.
Félix
