Hello Stefan,
we would like to deploy our own snap package on to the ctrx.docker-docker running on a seperate port (to be specific 51210).
We could deploy it and access it only locally but could not connect from other devices connected in the same network. Nmap shows the port is filtered. FYI, we are Rexroth partnes and not using container engine UI licensed but only from command line. We have also disabled firewall app on ctrlx. It would be grateful if you could guide us on opening of port. We tried everything like iptables and ufw etc. to forcefully open the port from OS side but nothing helped us. Please do not hesitate to contact for the further information.
Following are details of cntrlx device.
- UBUNTU Core 20 OS
Hardware Version
cx_m4_a
Material index
AD1
Serial number
7261403577853
Store Brand ID
boschrexroth
Store Model ID
rexroth-arch01
Store Serial ID
7261403577853
Type code
COREX-C-X3-11-ANNN-21.01-01RS-NN-NN
Type plate type
ctrlXCORE
Following is the nmap output from another ubuntu device connetced in the same network. 192.168.1.1 is the ip of ctrlx.
