Datalayer Table Size
rjduffy
Hello
When I try to create a datalayer provider of larger than 1MB i get the error that the datalayer is out of memory. I can however create multiple tables of 1MB, is 1MB the limit on the size of a datalayer table?
nickH
Hi
what do you mean with data layer table? Are you talking about RT Memory Ranges
The default maximum size for one RT-Memory Range is 1048576 Byte. But you could change this to your needs. See settings in the data layer here: datalayer/server/settings.
