CtrlX Core SDK build sample-snap failed with GCC 7.5.0 aarch64-linux-gnu
Hello community,
I'm trying to create the sample-snap "datalayer.register.node" for CtrlX Core. But it fails.
After switching cmake compiler to GCC 7.5.0 aarch64-linux-gnu message "Loading kit GCC 7.5.0 aarch64-linux-gnu" didn't disappears and building process failed.
Also this message didn't disappears.
If I create the snap for CtrlX virtual Core (GCC 7.5.0. x86_64-linux-gnu), building process works fine and the snap(app) is running without any problems on a virtual Core.
I think there is something wrong with the cmake cross compiler?!
Setup:
WSL Ubuntu 18.04
SDK V1.6.1 - RM20.11
Best reply by SimonG
While setup the SDK via WSL I obviously missed sudo apt-get install libssl-dev:arm64 ๐Ÿ™ˆ.
Now build process and snap is running without problems.
I have deleted the folders ( build, generated, ...).
But the messages still do not want to disappear.
How can I start a Cmake clean all in VScode?
Thanks for your suggestion.
View original
