Cloning the sdk from GitHub
Luschuerz
I was trying to clone the SDK from Github to the App Build environment.
Using the command ./install-sdk.sh does not work, as apparently github blocked the company IP-Adress due to too many requests. See the error message below:
"ERROR
{"message":"API rate limit exceeded for 194.39.218.22. (But here's the good news: Authenticated requests get a higher rate limit. Check out the documentation for more details.)","documentation_url":"https://docs.github.com/rest/overview/resources-in-the-rest-api#rate-limiting"}
Hint:
This error happens often because a proxy server is used.
In this case github registered a hugh number of requests from the same machine.
Continue or exit c/e?"
I then tried using the gh command to clone the github repo directly, however i keep getting the following message:
"Usage: gh repo [OPTIONS] USER_REPO
Try "gh repo --help" for help.
Error: Got unexpected extra argument (boschrexroth/ctrlx-automation-sdk)"
What other ways can I use to copy the sdk into the app build environment?
You can also download the SDK from the releases and unpack it to your development environment.
nickH
I would recommend to switch to the newest release. Since the version 1.18 of ctrlX WORKS, we provide a workaround for this problem. See the new error-message:
The workaround is to download the SDK form the link @CodeShepherd already shared. Please download the full repository (marked red in my screenshot). Then copy it to the home directory of your build environment and restart the script.
