What Apps will we need to use the IXON cloud connector on CtrlX?
From their website it looks IXON is based on using VPN. So is the CtrlX VPN App required? Will we have to manually set up the VPN or will the setup be similar to an IXON gateway where a setup file is generated and loaded onto the gateway.
Will it also use any other Apps? Maybe OPC-UA?
