04-11-2024 07:34 PM
Running IndraWorks 15V18 with the latest firmware and have the following error when using a Realtime ENIP scanner extension module on XM22. It cannont find the driver.
04-12-2024 01:41 PM
from IW online help ... it looks like, either the extention module is not detected correctly (mounted) or the module, back connector or XM2 is damaged (anyhow).
4 weeks ago
I found this was a problem specific to 15V18 firmware. When I swtiched to 15V16 or 15V20 the problem went away.
