04-01-2023 08:01 PM
I'm looking for information about reading and writing data in rfid tags with the id200 device. Following the example in the appendix a, I'm reading tag ids, but I'm not able to read and write data. I use an Allen Bradley plc with ethernet ip communication.
Many Thanks in advance.
04-04-2023 11:00 AM
I do not get your topic completely. Are you even using any ctrlX AUTOMATION or Indra family? If not this would be the wrong forum to place this question.
Aare using some foreign PLC right now and you like to now use ctrlX CORE?
Could you please add at least some device description file or manual of the RFID device?
06-16-2023 05:17 PM
Topic is closed due to long inactivity
