Hello to everybody,
Hi have a customer who is trying to access the ctrlx opc-ua server in anonymous mode. opc-ua server 1.12. Even if i have activated the "deprecated options" and activate the right policies from the front-end seems like the server is still asking for a login and password info. Is it normal?
here my security conf
really thanks
Hi MauroRiboniMX,
seems like a bug, will report it.
Thanks
Anonymous mode is not supported. You configured a none secure communication. In this case the password will be not encrypted, so anyone is able to see the password plaintext and we absolutely don't recommend that. Nevertheless the ctrlX OPC UA Server requires always a username and password, which is configured in ctrlX identity manager. See also here: https://docs.automation.boschrexroth.com/document/version/03/OPC-UA-Server-App_-Application-Manual/c...
Ok,
Really thanks for the answers guys.
So we still need user and password eve if we configure a none security and the anonymous access.
Thanks again 😎
Just for completeness i post here all the infos:
APP OPCUA-SERVER 1.12. Even if you se the Anonymous access and no encription at least username and password must be provided in any case. Here my configuration.
