Ctrlx Ethercat/j1939 converter slave device not found
MesutK
Hello ,
I have a ADFweb Ethercat slave device SW67E16 , But the ethercat master doesnt found it . attached the ESI file of the Ethercat to CANJ1939 converter .
Best Regards
Mesut
What is shown in ctrlX IO Engineering when you do an automatic scan of the fieldbus? Could you share your IO project here in the community or send it via a private message?
Hello ,
in the meantime i had contact with adfweb , the dipswicth was not in a correct position , so the communication works now , now i need to handle the data byte per byte. thanks
