Communication Size Limits
Hello
I have been asked to find out what Input/output byte size limitations the various Ethernet based commuications possibilities are with a CtrlX Core in Drive:
1. CtrlX OS  Profinet Device - Max number of  Input/ output bytes that can be declared?
2. CtrlX OS OPC UA Pub/Sub and Client - Any restriction on number of read/write data bytes in one packet?
3. CtrlX OS OPC UA Server - Any restriction on data table size?
4. CODESYS Ethernet IP Adapter - Max number of  Input/ output bytes that can be declared?
5. CODESYS Profinet Device - Max number of  Input/ output bytes that can be declared?
6. CODESYS TCP/UDP Function blocks - Max packet size?
7. CODESYS MQTT - Max packet size?  ( I have seen Solved: adjust Maximun packet size in the parameter list (boschrexroth.com) but it wasn't clear if there was any restriction)
I have done various offline tests (e.g. 4 and 5 above did not seem to generate any errors with huge IO size) and searched documentation but struggling to find definitive answers....maybe it is just a limit of network and hardware performance?
Many Thanks
Best reply by Thoomas
I start with some answers โ€“ links into the documentations:
    EN: https://docs.automation.boschrexroth.com/doc/3703895296/profinet-device-app-features/latest/en/?sel=AwelBYyyCYC5gBobShE8CcQ%3D
    DE: https://docs.automation.boschrexroth.com/doc/3703895296/profinet-device-app-features/latest/de/?sel=AwelBYyyCYC5gBobShE8CcQ%3D
    For clients see the links below and the links for the OPC UA Server:
    EN: https://docs.automation.boschrexroth.com/doc/894340029/eigenschaften/latest/en/?sel=AwegjCAsKq0EwC5gBpQWrKIlgMxA
    DE: https://docs.automation.boschrexroth.com/doc/894340029/eigenschaften/latest/de/?sel=AwegjCAsKq0EwC5gBpQWrKIlgMxA
    EN: https://docs.automation.boschrexroth.com/doc/412150158/eigenschaften/latest/en/?sel=AwegjCAsKq0EwC5gBpQWrKIlgMxA
    DE: https://docs.automation.boschrexroth.com/doc/412150158/eigenschaften/latest/de/?sel=AwegjCAsKq0EwC5gBpQWrKIlgMxA
For all CODESYS fieldbus communications see the link below and the linked sites by CODESYS directly:
CODESYS - Fieldbus Communication (boschrexroth.com)
  1. CODESYS Ethernet IP Adapter - Max number of  Input/ output bytes that can be declared?
  2. CODESYS Profinet Device - Max number of  Input/ output bytes that can be declared?
  3. CODESYS TCP/UDP Function blocks - Max packet size?
  4. CODESYS MQTT - Max packet size?  ( I have seen Solved: adjust Maximun packet size in the parameter list (boschrexroth.com) but it wasn't clear if there was any restriction)
View original
