We need to use the Network Oscat library and the problem is that with our current library version it comes up an error as the image shows below:
We have tried with a 32 bit PLC Application and it worked, so we assume that it is because the ctrlX Core is based on a 64 bit architecture,
Is there an alternative to this library? Does someone know if there is another version?
Thanks in advance,
