05-10-2023 11:52 AM - last edited on 06-20-2023 10:21 AM by CodeShepherd
In a Codesys project it was possible to change the Login Dialog of the WebVisu (https://faq.codesys.com/display/CDSFAQ/Creating+and+using+your+own+dialog)
However in the ctrlX PLC Engineering we can just select the Login Dialog of the VisuUserManagement Library
For the Standard Keyboards and Numpads it is possible to do your own keyboard and select it from this screen but it seems that it is not possible to select another Login Dialog,
So is it possible to create your own login dialog and select it from here? If so, how can we do that?
Thanks,
06-20-2023 10:11 AM
The link, you've added, can not be opened.
06-20-2023 10:21 AM - edited 06-20-2023 10:23 AM
I edited the link above to work now.
06-20-2023 10:29 AM
Now I'm able to open the link. The bracket at the end is not a part of the link. May you can add your project here?
06-20-2023 03:49 PM
06-23-2023 03:45 PM
Dear ericvergara.
Can you share the library created under the FAQ guide ( https://faq.codesys.com/display/CDSFAQ/Creating+and+using+your+own+dialog ) here?
06-26-2023 09:53 AM
11-03-2023 02:06 PM
Any news here? Can this topic be closed?
12-01-2023 11:21 AM
Yes,
This can be solved by creating your own library with your own Login Dialog Keypad,
12-13-2023 04:00 PM
Hi @ericvergara
Do you have step by step instructions for how to create the above? I did try looking for "visudialogs.library" but could only find the compiled file so could not open and then Save As to attempt to create an alternative .
Many thanks
